Engine knocking after no oil in car
160,000 MILES • 6 CYL • 4WD • AUTOMATIC
TNBAXTER
I started my jeep one morning and the engine was knocking. I checked the oil and there was none. I put oil in and knocking continued. I had someone look at it and he says I need my oil pump replaced. I wanna know if it's worth it because so many forums say when engines knock hard they need to be replaced to fix the car. This guy is asking $800 to replace the oil pump and is not even sure if it will solve my problem. He said if the oil pump doesn't change the knocking I need a new engine.
Btw when he was looking at it he was playing with stuff under the hood and the engine was not knocking anymore. But when he let go the engine knocked/jumped again.
Jul 31, 2014 at 6:16 PM
WRENCHTECH
  • 20,760 POSTS
The oil pump had nothing to do with this failure. You admitted there was no oil in the engine. The oil pump can't pump what isn't there and lack of oil will destroy the engine. I'd say you are probably looking at another engine but get a second opinion from another shop.
Jul 31, 2014 at 10:37 PM
TNBAXTER
Thanks
Jul 31, 2014 at 10:56 PM
WRENCHTECH
  • 20,760 POSTS
You're welcome
Jul 31, 2014 at 11:46 PM
