Engine knock?
106,000 MILES
CST843
  • 14 POSTS
I just replaced my head gasket and when I started car I'm hearing a loud knocking that gets faster as I rev the engine.
Nov 15, 2022 at 3:38 AM
  • 110,248 POSTS
Did this just start since the head gasket repair? Is the engine oil full and not contaminated with coolant?
Does the sound seem to be more at the top of the engine or the bottom? Can you record it and upload it for me to hear?
Let me know. In the interim, take a look through this link and let me know if anything mirrors what you are experiencing:
https://www.2carpros.com/articles/engine-noises
Nov 15, 2022 at 1:24 PM
CST843
  • 14 POSTS
Yes, just started after head gasket replace, it gets faster with rise in RPMs. Could it be the timing? It sounds like it’s toward the back of engine where intake is located.
Nov 16, 2022 at 6:45 AM
  • 110,248 POSTS
It sounds like a lifter. By chance, did you have the camshafts removed? Also, I need to know the engine size.
The sound, as I mentioned, sounds like a mechanical issue with a lifter or rocker arm. That's why I asked about the camshaft. As far as timing, other than the noise, it seems to run smoothly which would indicate the timing is correct. So, let me know the engine size, if anything was done with the camshafts, and (don't laugh) if you had any issues with the exhaust manifold install. Believe it or not, a leak can sound very similar to this, but my first thought is mechanical.
Nov 16, 2022 at 12:42 PM
CST843
  • 14 POSTS
I loosened and turned the cams to do the timing. The engine is a 1.4 turbo with hydraulic lifters.
Nov 16, 2022 at 3:01 PM
CST843
  • 14 POSTS
Would something I did cause the lifter to go bad or make that noise?
Nov 17, 2022 at 5:51 AM
  • 110,248 POSTS
When you tightened the camshaft bearing caps, how was it done? Believe it or not, they are all to be tightened hand tight and then in a specific sequence tightened one turn at a time until 71 Inch Pounds is reached. Is that what was done? Did you possibly overtighten them? People oftentimes don't realize there is a big difference between inch and foot pounds and over-tighten them.
See pic below.
Nov 17, 2022 at 8:48 AM
CST843
  • 14 POSTS
If it is just that I have to replace the lifters, do I have to replace them all on that side or just the one that failed?
Nov 17, 2022 at 8:49 AM
CST843
  • 14 POSTS
I moved the piston down loosened the cam sprockets and was able to turn them to time, didn’t say to loosen anything else didn’t touch the cam bearings caps.
Nov 17, 2022 at 9:01 AM
  • 110,248 POSTS
I don't think it is a lifter issue at this point. They are hydraulic and should accommodate slight movements. When you tightened the cams, did you follow the aforementioned procedures or something similar? Could you have over or under-tightened them?
Nov 17, 2022 at 9:02 AM
CST843
  • 14 POSTS
Reading through I tightened the cam sprockets to 37ftlbs but didn’t the extra 60 degrees. don’t know how I missed that. could that be something?
Nov 17, 2022 at 9:13 AM
  • 110,248 POSTS
I don't think that is causing the noise, but it would be a good idea to redo them. I was referring to the camshafts. Were they removed?
Nov 17, 2022 at 12:35 PM
CST843
  • 14 POSTS
No, never removed.. it shows to loosen cam sprockets all the way and take out the sprocket bolts to remove the head…when you reinstall since the slack is on timing chain you can turn the cams to time without loosening anything else?
Nov 17, 2022 at 3:46 PM
  • 110,248 POSTS
Okay, that is a good thing. LOL I was thinking the cams were removed.
Since this noise started after the repairs, recheck the cam sprockets to make sure nothing is loose. That is the one thing that is different than what was required.
It is running smooth other than the noise, correct? It appeared to be in the video, but I just want to confirm.
Nov 18, 2022 at 10:47 AM
CST843
  • 14 POSTS
Hey sorry it took so long to respond I had Covid.. I fixed the timing, and the noise is gone but it’s still getting coolant on top of my number 1 piston. I think I might have a crack in one of the ports in the head.
Dec 11, 2022 at 11:48 AM
  • 110,248 POSTS
It is possibly a crack, or the head is warped. You can have the head checked using magnaflux, but that requires it to be removed. Have you noticed white smoke from the exhaust? Are you getting a misfire code for cylinder 1?
Dec 11, 2022 at 1:10 PM
CST843
  • 14 POSTS
No symptoms at all just the wet piston top in cylinder 1…. I’ve been checking it with my scanner…car actually runs good. I can buy a new cylinder head from Rock auto for 1077 shipped I’ll probably go that route.
Dec 12, 2022 at 12:36 AM
CST843
  • 14 POSTS
No symptoms at all just the wet piston top in cylinder 1…. I’ve been checking it with my scanner…car actually runs good..I can buy a new cylinder head from Rock auto for 1077 shipped I’ll probably go that route
  • 110,248 POSTS
I would have the head tested first. That is a lot of money and I'm not sure if it is complete or if you need to switch parts to it.
Regardless, let me know what you decide and what I can do to help.
Dec 12, 2022 at 11:27 AM
