Engine issue, misfire on cylinder 1 and cylinder 2?
200,000 MILES • 5.4L • V8 • 2WD • AUTOMATIC
BIGACE850
I was told that my engine was bad that I need fuel injectors put in from the previous owner but when I took it by the shop, they told me that I need a new engine Due to a misfire on cylinder 1 and cylinder 2. The Intake Manifold is broken off from the coil pack in the back. The vehicle won't go past 25 MPH. When it shifts to 2nd gear i have no power output. Please help
Sep 19, 2024 at 11:07 AM
  • 55,548 POSTS
Did they say why the engine was misfiring? is it low compression if so, then yes you need a new or rebuilt engine. Here is a guide to help confirm the issue:
and
https://www.2carpros.com/articles/the-reasons-for-low-compression
We need more information to give you advice. Please go over this guide and get back to us.
Sep 20, 2024 at 3:47 AM
