Engine is running rough
85,000 MILES • 4.8L • V8 • 4WD • AUTOMATIC
DEVELOPER7
  • 42 POSTS
When I come to a stop the engine is shaking like it has a misfire, but when I gas it everything seems to smooth out? What is the problem?
Dec 18, 2015 at 2:33 AM
HMAC300
  • 48,601 POSTS
check for a vacuum leak like a hose off/cracked etc. also check for air leaks like duct work going to throttle, grommets. if it continues scan for codes and check fuel pressure with a gauge.
Dec 18, 2015 at 4:11 AM
