Engine is popping and sometimes won't start
3.1L • 6 CYL • AUTOMATIC
TOWNNASCAR
When started and running it makes popping noises. It was suggested that it was the injectors so I took out the fuel rail and injectors and replaced them with the ones from my 96 buick regal 3.1l cause I was told they were the same. Have the coils from my 96 and am switching them. I have changed the fuel filter three times and ran injector cleaner through the gas and then added a can of foam cleaner as suggested.
Jun 18, 2014 at 9:30 AM
HMAC300
  • 48,601 POSTS
if it's a popping noise check your valave train for a broken valve spring and or a bad pushrod.
Jun 18, 2014 at 11:10 PM
