Engine Idling rough until engine warms up
220,000 MILES • 3.9L • 4 CYL • 2WD • AUTOMATIC
CARMEN SC
We been having a recurring issue we backfired and the idle was rough and vibration in the vehicle, since check engine light was already on we had a Bank 1 Sensor 2 problem, (wire got tangled on the drive shaft and ripped out of the sensor). Got that replaced and reset the ECM to clear the code and to let the computer know the sensor had been replaced. Okay so she does fine if I let her warm up long enough to go in closed loop and we can drive her, but the OBD2 reader (still hooked up to vehicle to keep monitoring it) gave some interesting feedback when I tested all sensors wile my hubby was driving. OBD Module voltage 14.4V, DTC count 0, Misfire: Passed, Fuel System Passed, Components Passed, Catalyst :Not passed, Evaporative System Passed, Oxygen Sensor : Not passed, Oxygen Sensor Heater Passed.
We also have done a complete tune up. New spark plugs, replaced fuel pump last year after a similar problem (shop replaced it before testing the old one which turned out the old one had nothing wrong with it).
Shop had cleaned the distributor cap, after which it was running again not great, but not losing power either.
So yesterday we replaced the distributor cap and cables as well as rotor to complete the tune up. It is still doing the same as before replacing the O2 Sensor or similar.
My husband dropped me off at work after letting it warm up to go into closed loop, but he had to make stop somewhere for a while with a busy parking lot so he was unable to let the engine warm up enough to go into closed loop and the engine backfired several times and engine revved up so he pulled over and let it idle for about two more minutes after which the RPM went to normal idle than low back normal than low, but no more backfires. A few more minutes later he was able to drive normal with no issues. I am out of Ideas.
Nov 14, 2018 at 9:38 AM
  • 110,251 POSTS
I noticed that you indicated a few things did not "pass" when you mentioned different components/systems. Can you provide the codes you are getting? Also, since you have a live data scanner, can you tell me the fuel trims when it is cold? Also, what are they once it warms up? Closed loop indicates the O2 sensors are warmed up and the computer is adjusting air fuel mixtures based on their readings. If it runs normal in closed loop, then the sensors must be working.
Since this happens only when cold, I question a couple things. First, the engine coolant temp sensor (ECT). With your live data scanner, check to see what temperature the computer thinks it is. For example, if it is 50 degrees, is the ECT telling the computer that temperature or is it wrong. That can be an issue. Also, have you checked for engine vacuum leaks? Often times, when an engine heats up, a leak can be minimized or eliminated due to the expansion of metal when heated.
Here are a couple links to look through. One discusses the possible cause of a backfire, the other discusses how to check for a vacuum leak. Also, I added a fuel pressure test. That can cause an issue too.
I am not sure if these things have been tested, so I added them.
https://www.2carpros.com/articles/engine-backfires-while-running
If you could, let me know what codes are showing up to cause the "not passed" issues so I can better diagnose the problems.
Nov 15, 2018 at 11:12 AM
