Engine idle too low. Stumbles sputters on startup after sitting overnight . rougher idle when ac is turned on while ideling it fluxuates when clutch o
2005 FORD TAURUS
139,050 MILES • 3.0L • 6 CYL • FWD • AUTOMATIC
GREGERY
  • 7 POSTS
I have a 2005 ford tauras 3.0l v6 auto ohv engine . Sometimes on start up car stumbles and sputters for 2 or 3 seconds or if you hit the gas pedal right away it clears up immediately. But once car runs for a minute the idle drops close to 550 to 650 rpm and kind of barely fluxuates. Then if you turn on ac before driving it bogs down for 2 seconds and causes a rougher idle condition.no check engine light is on. It just seems it should be ideling around or close to 1000 rpm not 500 to 700 rpm. What are your thoughts?
Aug 6, 2015 at 10:51 PM
HMAC300
  • 48,601 POSTS
try cleaning throttle plate on both sides an diac hole with choke cleaner then check fuel pressure with a gauge auto parts rent it.
Aug 6, 2015 at 10:55 PM
GREGERY
  • 7 POSTS
Thanks i will try that and get nack to you
Aug 7, 2015 at 12:17 AM
GREGERY
  • 7 POSTS
Back to you lol
