Engine idle problem
200,000 MILES
OXYGENBW
Engine starts but loses power when it warms up..almost as if car has no fuel and switches off replaced fuel pump,engine was recently overhauled...is it maybe a sensor issue..Please advise on possible faults,note that I have not done an engine diagnosis yet using a machine
Feb 24, 2016 at 6:34 AM
WRENCHTECH
  • 20,758 POSTS
This car isn't sold here in the US so I can't be a whole lot of help but the first thing you need to do is have the codes read to see if you can come up with a starting point.
You might also want to test the fuel pressure although I don't have the pressure spec available to me.
Feb 25, 2016 at 1:32 AM
