Engine idle is rough when it is warm outside
147,800 MILES • 5.7L • V8 • 4WD • AUTOMATIC
STEVEN DEY
  • 5 POSTS
When I start my vehicle and it is warm outside, (currently in ND it's between mid 50's and mid 60's) the idle is so rough and you can smell the fuel dumping in. And then after about thirty seconds or so, the idle will smooth out. I can turn the vehicle off and start it about thirty minutes later and it will do the same thing. ECT is new, replaced about two years ago, spark plugs were changed about a year ago, could be fouled now with it running rich, IAC is a also fairly new. When the vehicle is all warmed up and I am idling in third at a stoplight, my idle will drop down to 500 sometimes 450, when it hits 450 it bucks a little bit and tries to stall, I put it in neutral and it's fine. Also, if I am at very low speed and crank the wheel to get into my garage it sometimes will cause the engine to stall out but starts right back up. I replaced the engine with a new GM Goodrich crate motor almost three years ago. The issue seems like it might have started after that. I do have an exhaust leak where the exhaust manifold connects with the Y-pipe on both sides. Exhaust bolts broke when I put them back together after installing the new engine. I have checked for vacuum leaks and haven't found any and also my fuel mileage absolutely sucks.. I am getting around 6-8 miles to the gallon. Any help and or any suggestions to things I can test would be greatly appreciated. Thanks
Apr 23, 2019 at 5:47 AM
Hi Steven,
You may have a couple things going on here but we need to start with fixing the exhaust leak. That could be throwing off your O2 and effecting the idling issue at a stop light.
As for the rough running when starting when it is warm out, most likely that is your intake air temp sensor. The PCM will only look at a couple of sensors when in open loop when it is first started. These are generally, IAT, ECT, MAF, and maybe MAP. Once the PCM sees the ECT has reached operating temp, it will start monitoring the o2 sensor data and this is why it smooths out because it sees that it is way to rich when it switches to closed loop.
Here is a resource that will help explain this further. Step 4 and 5 are most important in your case.
https://www.2carpros.com/articles/repair-lean-mixture-codes-p0171-or-p0174-on-some-manufacturers
In my opinion, you need to get a scan tool and hook up to the vehicle to look at what these sensors are doing. Plus, I imagine you have some DTCs. However, there are ways to test some of the sensors without a scan tool. Here is a video for the MAF:
https://youtu.be/p0ocaDmcAIM
Here is one for the IAT and ECT:
https://youtu.be/nksLy9MS0IQ
I suspect what is happening is, the intake air temp sensor is reading wrong which is why it only does it when it gets warmer outside. Or the mass air flow sensor is reading more air then what is there so the PCM is adding more fuel.
Let me know what you find and we can go from there.
Apr 24, 2019 at 9:56 AM
STEVEN DEY
  • 5 POSTS
This is a 1995 Chevrolet Tahoe 5.7 TBI. No Vortec. No IAT sensor, No MAF sensor. I have put a scan tool on it, no trouble codes no check engine light. I did live stream data from it.
https://www.dropbox.com/s/tmbgd25ue7jvacf/2019-04-21_12.01.38.csv?dl=0
Apr 24, 2019 at 1:43 PM
That Steven. This is great information. If this issue started after you put this crate engine in, you may be missing this intake temp sensor. The PCM is looking for it and is recording it as -40. This is indicative of an open in the wiring or sensor. If it is not there, then this would explain the open. Either way, the PCM is looking for it and not seeing it. This will effect the way the engine performs in open loop when it is warm outside. When it is cold, the engine will run a little better because the -40 is not as far off so it may not be as noticeable. I see that the GM TBI crate engines are direct replacements for this vehicle but don't see where it says the IAT is not needed.
The next thing is the MAP seems off. I assume the MAP in your recording is measuring in vacuum not pressure because at key on, the MAP matches your BARO. Then quickly your MAP shows load on the engine or possibly throttle input, even though your throttle remains at idle. The PCM is command an RPM of 890 but clearly the RPM is ranging and this indicates a rogue sensor that the PCM is looking at.
If it were me, I would investigate the intake/manifold air temp sensor and then replace the MAP and retest. This is assuming that when the crate engine was installed, the PCM was re-calibrated for the engine change. What engine was in this prior? Was it a Vortec engine?
Apr 25, 2019 at 2:53 AM
STEVEN DEY
  • 5 POSTS
The engine I got was a direct replacement of my old one. my vehicle never had a vortec in it, and the old engine didn't have an IAT sensor either. The MAP sensor is new as well I have thrown new parts at this thing because of this issue. Almost all the sensors if not all of them in the engine bay have been replaced in the last two to three years. And I put the engine in myself, I didn't do anything with the PCM. I just assumed since it was the same motor going in that it wouldn't matter.
Apr 25, 2019 at 7:16 AM
So if the PCM is looking for and not getting a good IAT sensor (in this case it is calling it a Manifold Temperature Sensor) then that can definitely effect open loop operation. The engine has to have some sensor that gives it what the ambient or intake temperature is. The reason is, the PCM uses ambient/intake temp, engine temperature and MAP to determine (guess) what the best amount of fuel is needed to operate properly until it gets up to temp so it can start looking at o2 data and others. At that point it will adjust and the engine smooths out.
Based on what you are saying, your issue is at open loop. Everything involved in that is, PCM, MAP, any intake temp/ambient temp sensor, and Baro. If Baro is reading properly, the MAP has been changed, you don't have an intake/ambient sensor (still think we are missing something here) then I would assume the PCM is just not interpreting this data correctly.
This could cause it to over fuel, so it commands your injectors to open too long, which causes your RPM to range, which explains why your MAP is all over the place.
If you are going to replace the PCM, I would research what PCM has the best software for the replacement engine you have. Not just replace it with the one for the way the vehicle was built. Maybe call the engine supplier and ask if they offer a PCM to go with that engine. Again, I understand that this was a replacement engine for this vehicle but the fact that the PCM is looking for something that doesn't appear to be there, something has to be different.
Taking a step back, you said this didn't start until you replaced the engine. If it happened pretty quickly after replacing the engine then we need to find out what is different between the last engine and this one, because clearly it is not acting properly.
Apr 26, 2019 at 3:43 AM
STEVEN DEY
  • 5 POSTS
So I had another ECM laying around in my garage, I threw that in and took the other one out. My idle has seemed to lower down to normal now. But I have a question about about the timing, so my base timing is set to 0 degrees like it should be with brown and black wire unplugged. When it's plugged back in and engine is idling warm. How many degrees does the timing advance advance the timing normally for my engine? At idle mine is advancing it anywhere from 7 to 9 degrees, that seem kinda low to me, but I could be wrong.
Apr 26, 2019 at 2:39 PM
Great to hear the idle is smoothed out. I wonder if this PCM shows that manifold temp sensor as well? Just if you have time send another live data with this PCM. I am just curious.
You are correct. Base is 0.
It does not seem low on idle with no load. Put the parking brake on and block the tires, put it in gear so it loads the engine and see what the advance goes to. However, the key thing is how it is running. You can bump it up a little for base timing if you like. You can play with a little bit but I would not go to far because then you will start affecting acceleration and fuel mileage. However, if it runs smoother at 2-3 base timing which puts it up to around 10-12 with advance then go with that. Basically, the engine will tell you where it is happy so you are looking for when it sounds really smooth or what they call a rolling idle.
Apr 27, 2019 at 4:19 AM
STEVEN DEY
  • 5 POSTS
So I contacted the app developer of the app I am using to collect the live stream data. That Manifold Sensor Data is built into the data log on the app in case vehicles have one.
Apr 27, 2019 at 10:17 AM
That clears it up. Thanks.
Apr 27, 2019 at 11:12 PM
