Rough engine idle
209,000 MILES • 2.0L • 4 CYL • AUTOMATIC
WASHIJ11
  • 7 POSTS
Hello. I have the car listed above SXT model. I have recently replaced the spark plugs, coils, and the throttle body. Still having the same problem. I noticed oil in the second cylinder while replacing the spark plugs. Could a blown head gasket be the source of my problem? Or what else should I be looking at?
Jan 16, 2020 at 7:26 AM
It can but oil in the cylinder is more likely caused by the rings failing.
We need to start with the compression check to see what we have. More than likely you will find it low on the cylinders that you found oil. If that is the case then we need to do a cylinder leakage test.
Let's start with compression and go from there. Thanks
Jan 16, 2020 at 8:38 AM
WASHIJ11
  • 7 POSTS
Okay, so the compression test would be the first step in figuring out why it’s idling rough. It happens when accelerating intermittent.
Jan 16, 2020 at 8:48 AM
Since you covered the most common components and found oil, I would just check the base engine by checking compression because if that is not okay then nothing else really matters. However, if that is okay then we can dig deeper.
Think of it as checking the foundation on a house. No need to look to see if the kitchen is nice if the foundation is no good.
We may have a fuel issue but again, that will be the next thing after making sure compression is okay.
Jan 16, 2020 at 10:57 AM
WASHIJ11
  • 7 POSTS
I have replaced the valve cover gasket. It ran for for about 20 minutes and shut off. Now the timing is off. I put a scan tool on the car p2088, p2090, p2017and p2004. I purchased both camshaft sensors, intake manifold runner control and a IAT sensor. Haven’t installed yet. I’m just unsure of the timing issue.
Feb 21, 2020 at 10:50 AM
What makes you say the timing is off? Because you have 2 cam sensor codes? These are circuit codes and not actual timing issues. Let me know if there is something else and we can go from there. However, I bet these are all related.
Again, before we tackle these, just let me know why you say there is a timing issue. Thanks
Feb 22, 2020 at 10:42 AM
WASHIJ11
  • 7 POSTS
I replaced the valve cover gasket and seals. After that it ran for approximately 20 minutes then the car shut off and wouldn’t start. When I try to crank it there is rattling noise on the left side of the engine. You know where the chain would be. I plan on installing the two new cams and IAT sensor later this week.
Feb 22, 2020 at 9:14 PM
Okay. Got it. Rattling is definitely a sign of a chain issue but it may not be out of time. It could just be a tensioner issue. Unfortunately there is no way of knowing without tearing it down. So for what it is worth, if it were me, I would probably do the same you are doing.
Keep us updated. Thanks
Feb 23, 2020 at 12:49 AM
WASHIJ11
  • 7 POSTS
Ok will do.
Feb 23, 2020 at 4:18 AM
Thanks. We will wait to hear back.
Feb 24, 2020 at 6:38 AM
