Engine will not idle
FARMERJOE
  • 2002 CHEVROLET SILVERADO
  • 4.3L
  • 6 CYL
  • 4WD
  • 112,678 MILES
This truck was parked due to sons deployment. Went to start it and battery was drained. After charging started truck, it will not idle. It runs okay at anything over idle just no idle. I have driven this truck in the past and idle was okay pre-drainedd battery.
Monday, October 2nd, 2017 AT 8:38 AM
JDL
  • 16,098 POSTS
Sometimes when battery voltage is lost, some systems may have to relearn. Usually just driving it a while and it will relearn itself. You can also check and clean the IAC/idle air control, see if it helps? You may need to clean throttle body and those small passages. Any applicable trouble codes?
Monday, October 2nd, 2017 AT 9:31 AM
RENEE L
  • ADMIN
  • 1,260 POSTS
Hi FARMERJOE,
All of us at 2CarPros want to thank your son for his service. We truly appreciate him and all of our military service men and women.
Sincerely,
The 2CarPros Team
Monday, October 2nd, 2017 AT 12:05 PM
FARMERJOE
  • 15 POSTS
Thank you all. L will try driving it for a while to see if that helps the idle and I appreciate you comment thanking for his service our family has always served.
Monday, October 2nd, 2017 AT 3:03 PM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 47,526 POSTS
Here is a guide that deals with the problem you are describing:
https://www.2carpros.com/articles/engine-stalls-idles-too-high-low-after-dead-or-replaced-battery
Thanks again.
Please use 2CarPros anytime, we are here to help. Please tell a friend.
Cheers, Ken
Tuesday, October 3rd, 2017 AT 12:15 PM
