Engine hot A/C off (code)
2009 CHEVROLET IMPALA
134,000 MILES • 3.5L • V6 • 2WD • AUTOMATIC
TMBENNETT59
Temperature gauge goes to zero and cooling fans for engine comes on when engine is cold? Changed temperature sensor and connection and wire. Unhooked battery clear code. Seem to work fine for a day and same problem comes back?
Nov 28, 2018 at 5:35 AM
Good evening,
What is the code that was set?
The AC will shut down under high temperature conditions. That is programmed into the software.
Nov 28, 2018 at 5:51 AM
TMBENNETT59
I unhooked the battery for one hour. Hooked the battery back up took the car on a five hundred mile test drive every thing to be working fine.
Nov 29, 2018 at 1:04 PM
All you did was tell the PCM to forget the code. The issue is still there and will come back. Doing that procedure does not fix anything as the issue has not been addressed.
When it returns let us know and we can continue.
Nov 29, 2018 at 8:55 PM
