Engine hiccups while accelerating
147,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
KYLE102
When my car hits 20 mph from a stand still the engine loses power and the car jerks a little and rpm drops low too. I think its the throttle body or the throttle position sensor but i need a second opinion. It's also very consistent, it happens every day. It also idles extremely low at traffic lights and the car has a lot of vibration and shaking. It stalls occasionally too because of the low idle.
Mar 11, 2019 at 12:52 AM
SCGRANTURISMO
  • 4,897 POSTS
This could be a fuel filter that is starting to plug. Anyway, I have included a few links for you to go to down below.
https://www.2carpros.com/articles/symptoms-of-low-engine-power
https://www.2carpros.com/articles/engine-has-low-power-output
https://www.2carpros.com/articles/how-to-change-a-fuel-filter
Please go through these guides and get back to us with what you find.
Thanks,
Alex
2CarPros
Mar 11, 2019 at 1:02 AM
KYLE102
I'm pretty sure when I got the car at 140,000 i think my parents and I replaced the fuel filter. I've read a lot of forum posts lately and it seems like a lot of Chrysler cars have this problem with their transmissions/parts and the majority of the problems were with the throttle bodies and throttle positioning sensors. But I will double check on the fuel filter.
Edit: Did not change the fuel filter. I looked at the articles and I still think it has to do with the MAF or Throttle body and TPS. I'll keep doing research.
Mar 11, 2019 at 1:05 AM
  • 55,743 POSTS
Yes, this is a classic throttle body being dirty issue. What happens is the PCM loses correlation between the throttle body and computer causing it to go into limp mode. Here is a guide that will help you fix the problem:
https://www.2carpros.com/articles/reduced-power-limp-mode
Mar 11, 2019 at 8:20 AM
KYLE102
Awesome, thanks so much.
I think its time for a new throttle body anyway. I just hit 148,000 today anyway.
Thanks again!
Mar 11, 2019 at 8:25 AM
  • 55,743 POSTS
Let us know if it works. :)
Mar 12, 2019 at 3:17 AM
KYLE102
Update!
Put in the new throttle body earlier this morning, completely different car. It drove amazing on the initial test. I had to reprogram it a little to fix some rough idling but overall it fixed the hiccup problem and the car drove like it was brand new.
Mar 14, 2019 at 1:33 AM
  • 55,743 POSTS
Good to hear, please use 2CarPros anytime we are here to help.
Mar 14, 2019 at 5:30 AM
