Engine hesitation/sputtering
108,000 MILES • 3.9L • V6 • 2WD • AUTOMATIC
NATHANIEL FIELDS
Typically from a stop the engine will hesitate to go and or sputter and then go real fast. I have a brand new rebuilt engine with only 500 miles. I checked the compression on it and it is well.It has new spark plugs,spark plug wires,coil pack,fuel injectors, and all brand new throttle body sensors and which I checked on a data stream to make sure they were working properly.
May 24, 2021 at 2:40 AM
  • 55,691 POSTS
Can I ask which rebuilder did the engine? also does the engine seem to have the same power as the old engine? It sounds like you may have a bad MAP sensor. this guide can help us fix it with the MAP sensor location in the diagrams below:
https://www.2carpros.com/articles/engine-hesitates
We should check the fuel pressure as well and check the fuel filter.
and
https://www.2carpros.com/articles/how-to-change-a-fuel-filter
May 25, 2021 at 3:30 AM
NATHANIEL FIELDS
The rebuilder was AutoZone this is my 2nd one the first one had low compression on 2 4 and 6. So I made sure to check compression on this Ken and it is good.The fuel pressure is good.I recently put a new MAP sensor on it I tried to tell if it was good with a OB2 reader but couldn’t tell.I’ll leave that video below.
May 25, 2021 at 3:47 AM
  • 55,691 POSTS
With those reading it seems like we may have a bad cylinder. let's remove the spark plugs and take note of the color. We are looking for the plug that is different from the rest. Then let's do a compression test. this guide can help:
May 26, 2021 at 3:41 AM
NATHANIEL FIELDS
I checked the spark plugs and compression already it’s all good.
May 26, 2021 at 4:30 AM
  • 55,691 POSTS
how did the spark plugs look was one dark or black? This can mean a bad injector. Also does it have a new MAP sensor? let's check for vacuum leaks.
May 27, 2021 at 2:25 AM
