Engine hesitates/jerks when cold
46,600 MILES • 2.0L • 4 CYL • 4WD • AUTOMATIC
MARK87
  • 61 POSTS
I have the vehicle listed above ix35 model. during cold engine my car hesitate/jerk during acceleration for sometime then it runs okay. what I would like to know is what can cause this problem?
Feb 12, 2020 at 9:57 PM
TOUGHDIVER
  • 226 POSTS
Probable causes could be ignition wiring, spark plugs and spark plug cables, I'm attaching repair guides and component location below. Let us know if you need more information.
https://www.2carpros.com/articles/how-to-tune-up-a-car-engine
Thank you
Joe T.
Feb 13, 2020 at 5:12 AM
MARK87
  • 61 POSTS
The previous owner of the car hasn’t done any servicing for almost a year now, Will do a complete servicing of the vehicle. Do you think its advisable to replacement the fuel filter as well??
Feb 13, 2020 at 10:31 AM
TOUGHDIVER
  • 226 POSTS
The fuel is part of the fuel module in the gas tank it is to last the life of the vehicle or fuel pump. It would be costly to place it and it would not need to be service unless you have a faulty fuel pump. let us know if there is anything else can can help you with.
Thanks
Joe T.
Feb 14, 2020 at 1:57 AM
MARK87
  • 61 POSTS
Thanks, will go for the spark plug replacement.. as for this symptoms i notice as well when i press the gas pedal i could hear a like a misfire from the exhaust(it's not like a constant flow of the exhaust) have to press the gas pedal hard to be able to get the car moving. it's like a lack of power.
Feb 14, 2020 at 10:42 AM
TOUGHDIVER
  • 226 POSTS
A 4 cylinder engine if it drops a cylinder because loss of spark it would definitely have low power. I feel your going to see a big improvement after the tune up. Please let us know how everything turns out.
Thanks
Joe T.
Feb 14, 2020 at 12:22 PM
MARK87
  • 61 POSTS
Hi Joe, just for an update: I have replace the spark plugs as well as service the car air filter etc. now the car is running smooth no hesitation from the engine.
Many thanks for the advice.
Feb 26, 2020 at 3:01 AM
TOUGHDIVER
  • 226 POSTS
I'm glad to hear that we appreciate the update and thanks for choosing 2CarPros.
We are here when you need us.
Thanks again.
Joe T.
Feb 28, 2020 at 12:47 AM
