Engine has miss, Bank 2 to lean.
100,000 MILES
DREAMSPAWN
My truck started missing around a month ago it would come and go, i changed all spark plugs and tested Coils and reset ecu via battery disconnect. But lately it has gotten worse and the CEL is showing Bank 2 to lean.
May 15, 2013 at 10:41 AM
did you do a compression test??
was there any coolant in the well with the plug??? common for intakes failing causing missfires
May 15, 2013 at 11:01 AM
DREAMSPAWN
no fluid not done compression test yet
May 15, 2013 at 11:24 AM
STEVE MAC
  • 6 POSTS
Check map sensor and look for vacuum leaks
May 16, 2013 at 9:03 AM
