Crank not start, engine fuse blowing?
240,000 MILES • 5.9L • V8 • 2WD • AUTOMATIC
OLLIE2022
  • 49 POSTS
I have been having stalling issues, so the code was clutch solenoid switch replaced that and distributor cap and button and now this every crank no start.
Jul 26, 2022 at 12:26 PM
  • 110,248 POSTS
Which fuse is failing? Also, when you say clutch solenoid switch, are you referring to the torque converter clutch solenoid? Also, does the fuse fail as soon as it's installed, or do you have to crank the engine for it to fail?
Jul 26, 2022 at 3:15 PM
OLLIE2022
  • 49 POSTS
#9 full crank then fuse blows n.
Jul 27, 2022 at 3:34 PM
  • 110,248 POSTS
I attached a pic from the wiring schematic below. Fuse 9 powers several relays in addition to the PCM. It could be any of the circuits that have a short.
Here is what I need you to do: Remove one relay at a time and see if the fuse doesn't fail with one of them out. This way, we can narrow down where the issue is coming from.
Let me know what you find.
See pic below.
Jul 28, 2022 at 5:44 AM
OLLIE2022
  • 49 POSTS
10-4. Thanks, i'll let you know.
Jul 30, 2022 at 3:43 PM
OLLIE2022
  • 49 POSTS
Ignition Run / Acc is the culprit.
Jul 31, 2022 at 10:52 AM
  • 110,248 POSTS
I just went through four different schematics and can't find a relay with that specific name. Are you referring to the ASD relay?
When I work back through the schematic, I find a fuse that sends power to the ignition switch (ign/acc) but that goes to the ignition switch and then to the schematic above. By chance, do you mean the fuse was bad?
Jul 31, 2022 at 3:05 PM
OLLIE2022
  • 49 POSTS
I took out that fuse and the #9 didnt blow upon crank on the pdc The fuse isnt bad either
Aug 1, 2022 at 1:23 PM
  • 110,248 POSTS
Okay, then we need to remove one of the relays at a time to see which one is causing it to fail when you try starting it. Fuse 9 powers the relays.
If you look at the schematic above, I highlighted the relays involved.
Aug 2, 2022 at 5:50 AM
OLLIE2022
  • 49 POSTS
Ignition switch spring is out of shape and might be arcing behind key cylinder.
Aug 2, 2022 at 6:08 PM
  • 110,248 POSTS
That is very possible. I don't know if you need them, but I attached the directions for the removal and replacement of the switch.
Take a look through them and let me know if you have questions.
Take care and let me know how things turn out for you.
Aug 3, 2022 at 12:01 PM
OLLIE2022
  • 49 POSTS
Still blowing fuse 9. After. new ignition switch. What accessories would cause this problem? The fuse that i took out was ignition//acc.
Aug 11, 2022 at 2:58 AM
  • 110,248 POSTS
Does it fail as soon as the battery is connected, or do you need to turn the key on for it to happen?
If it fails when the battery is connected, the short is before the switch. If you have to turn the key on, then it's after. Let me know.
Aug 11, 2022 at 6:45 AM
OLLIE2022
  • 49 POSTS
When I turn the key to start. I changed the battery wire with a split battery wire with a pointy connector on the post. And the connection on the split is way larger than the black wire it connected to. With no crimp. Or solder just twist and electric tape?
Aug 11, 2022 at 12:43 PM
  • 55,711 POSTS
I would solder the connection, also I would disconnect the oxygen sensors to see if the fuse blows, then the ignition coil(s) then each injector until the fuse doesn't blow.
Aug 12, 2022 at 3:40 AM
OLLIE2022
  • 49 POSTS
Okay my crankshaft sensor was. Fried. Seven parts ago, could my distributor be bad?
Aug 13, 2022 at 11:46 AM
  • 110,248 POSTS
Have you been able to make any more progress? As far as the distributor itself is concerned, I don't feel that would be the issue. Have you been able to try what Ken suggested?
Aug 14, 2022 at 12:11 PM
OLLIE2022
  • 49 POSTS
Tomorrow, I'll try them, i bought a coolant temperature sensor because the temperature gauge quit working the day before the Fuse problem. my keyboard on my phone is acting up i apologize for the capital letters and apostrophes.
Aug 14, 2022 at 3:46 PM
  • 110,248 POSTS
No problem with the letter issue. LOL Thanks for the update. Let us know if there is anything we can do to help.
Aug 15, 2022 at 11:48 AM
OLLIE2022
  • 49 POSTS
I have no clue on how to disconnect the injectors.
Aug 26, 2022 at 8:57 AM
  • 110,248 POSTS
The fuel rail needs to be removed first. I attached directions below specific to your vehicle. Make sure the battery is disconnected before you start and keep in mind the system is under pressure.
Also, here is a link that I feel is more detailed. However, it isn't specific to your vehicle. Between the two, you should be fine.
https://www.2carpros.com/articles/how-to-replace-a-fuel-injector
Aug 26, 2022 at 12:28 PM
OLLIE2022
  • 49 POSTS
Okay, took transmission pan off and had wires pinched at the shop, i borrowed a obd1 n 2 code reader and its saying transmission fluid temperature sensor. any idea where it is located?
Sep 28, 2022 at 1:06 PM
  • 55,711 POSTS
Good find, that will do it, for the transmission fluid temperature sensor please start a new question. Please post your new question here, you must be logged in.
Cheers, Ken
Sep 29, 2022 at 6:29 AM
