Cranks no start issue
238,000 MILES • 3.8L • 6 CYL • 2WD • AUTOMATIC
VIENNA
I replaced the fuel pump and I am going to replace the fuel filter, but I am getting fuel up to the engine block. My car will start and run for about ten minutes then completely shut off. I get it to crank over like it wants to start but will not. I am at a loss on what else could be causing it not to start.
Jun 23, 2018 at 12:22 AM
  • 55,823 POSTS
When it wants to start can you use starting fluid to make it run? If so we can start looking at the fuel system. If not it will be an ignition issue. This way we can narrow it down.
Cheers, Ken
Jun 24, 2018 at 5:52 AM
VIENNA
Thanks, we tried starting fluid and also changed the crank sensor. The ignition was the next thing I was thinking and dreading.
Jun 24, 2018 at 5:53 AM
STEVE W.
  • 15,423 POSTS
So you tried the starting spray after it shuts down and it did not work? That sounds like you are losing spark. Somewhat common for the ignition module under the coils to fail this way.
Easy way to test, run it until it shuts down, pull a wire and use a spark tester to check all three coils. As you say it "wants to start" it may lose spark on one or two coils and try to fire on the others. My SOP if that is the case is to move a good coil to the "bad" coil and test again. If still no spark replace the module and the coils. If you get spark then you can replace just the coils.
Jun 24, 2018 at 6:07 AM
VIENNA
The sparks maybe need to be changed just in case Checked them after finding that the crank sensor was not the issue. But I have a feeling it might be the ignition module.
Jun 24, 2018 at 6:32 AM
STEVE W.
  • 15,423 POSTS
Test for spark first. It would take completely gone spark plugs to keep it from at least running. A simple tester right at the coils should show if you are losing spark.
Jun 24, 2018 at 8:25 AM
VIENNA
Thank you, I will check.
Jun 24, 2018 at 8:28 AM
  • 55,823 POSTS
Here is a guide to help:
Cheers, Ken
Jun 25, 2018 at 3:45 AM
