Engine free spins
240,455 MILES • 2.2L • 4 CYL • 2WD • MANUAL
RICKY ALLEN CAGLE JR.
It's sounds like the timing belt is broke but it has a chain. I changed it because I thought that was the problem. I also changed the firing rail and module then just found out that my girl put two gallons of something she found in the yard. I do not know.
Sep 8, 2019 at 5:12 PM
Good morning,
I would start by doing a compression test to verify there is no valve damage.
Can you upload a video of the engine while cranking?
Sep 8, 2019 at 11:24 PM
