Engine swap?
125,000 MILES • 4 CYL • 2WD • MANUAL
BHAMDOC1973
  • 2,007 POSTS
I have the vehicle listed above with a 2.5l and 6 speed manual, will an engine from an aid automatic fit?
May 20, 2023 at 2:04 AM
  • 110,248 POSTS
If the engine is from the same year, make, and model, it should work. I believe the only automatic transmission used was an FW6A-EL. What are you referring to when you say AID?
The transmission bell housings should be the same, auto or manual, so it shouldn't be an issue.
May 20, 2023 at 3:22 PM
BHAMDOC1973
  • 2,007 POSTS
Sorry meant to say AWD.
May 20, 2023 at 10:08 PM
  • 110,248 POSTS
No problem whatsoever. I was concerned that you had something I never heard of. LOL
Regardless, if you have a chance, let me know how things turn out for you.
May 21, 2023 at 12:12 PM
