Engine randomly shuts off while driving
2004 BUICK LESABRE
150,000 MILES • V6 • 2WD • AUTOMATIC
DAVIDSAINTS
When I drive my vehicle it will randomly shut off when I'm driving. Both of my turn signals will turn on right before my vehicle shuts off. Once it shuts off the battery will not turn on. Headlights still work, all power still works. The odd part is when I turn my headlights off then back on the car will start back up but will experience the issue again. Once started both turn signals will be on. I had the battery tested original and it needed to be replaced. I bought a brand new battery, but later that day it happened again. I even started the car and disconnected the battery and the car was still running to check the alternator. I'm in a big stump on this one.
Feb 19, 2020 at 9:32 PM
Good morning,
Never, never, ever remove a battery cable while the engine is running. It tests nothing and can damage the modules and the alternator.
You need a voltmeter to test the alternator to be sure it is putting out 14 to 14.5 volts.
I would start by cleaning the battery cables. You have 2 cables stacked on the positive side that need to be totally clean for all systems to work.
I would start by
Feb 19, 2020 at 11:05 PM
