engine fails to start without use of starter fluid
300,000 MILES
MDJMORRISON
93 buick roadmaster limited, did tune up, plugs wires cap rotor. set timing. changed leaking oil pressure sensor. now car will not start without use of starter fluid and keeping rpms above 1500to 2000. also put in new fuel pump, filter, tps sensor, injectors and full gasket kit for tbi... still no change?? help, please
Apr 16, 2013 at 10:45 AM
what is the actual fuel pressure??
Apr 16, 2013 at 11:37 AM
