Code P1336, this code was nonexistent?
55,540 MILES • 1.5L • 4 CYL • 2WD • AUTOMATIC
RICARDOA
My vehicle listed above has a coolant leak and damaged the engine. Ford had the extended warranty, so they fixed the engine, but a new code came up to them, P1336. This code was nonexistent until they manipulated the engine. Why could this happen?
Mar 26, 2024 at 6:01 AM
  • 55,628 POSTS
The P1336 code in a 2017 Ford Escape is generally related to the crankshaft position sensor performance. So, it looks like the wiring/connector is damaged or the sensor is no good, here is the location of the sensor so you can see what needs to be done or what to look for to help fix it yourself. Check out the images (below). Please upload pictures or videos in your response of the problem so we can see what's going on.
Mar 26, 2024 at 6:49 AM
  • 55,628 POSTS
anything?
May 11, 2024 at 5:56 AM
