Engine will not start after new transmission installation
280,000 MILES • 5.2L • V8 • 4WD • AUTOMATIC
CJNJAM
  • 5 POSTS
I just installed a used transmission into my truck and when I went to start the engine I turned the key over and nothing happened.
Jun 1, 2016 at 7:50 AM
CJNJAM
  • 5 POSTS
it does not turn over. It does not crank there are no clicking noises.
Jun 1, 2016 at 8:27 AM
HMAC300
  • 48,601 POSTS
try resetting security system . lock drivers door then unlock door and see if it starts. if not then look online to see how to do it for your truck. also recheck your work may have a battery cable disconnected.
Jun 1, 2016 at 9:00 AM
HMAC300
  • 48,601 POSTS
CJNJAM
  • 5 POSTS
I do not have the door key to unlock the door manually only the key fob do you know of any other way to reset it or disable it completely
Jun 1, 2016 at 9:53 AM
CJNJAM
  • 5 POSTS
I do have power to the truck and the battery has the proper voltage
Jun 1, 2016 at 9:57 AM
CJNJAM
  • 5 POSTS
when I turn the key on started there is 1 click coming from my fuse panel under the hood and 1 click sounding like it's coming from back of engine or transmission
Jun 1, 2016 at 10:05 AM
HMAC300
  • 48,601 POSTS
it may be the starter hitting the flywheel and something may be wrong like a shim missing. make sue there is battery power to the starter same as battery. recheck wiring there and fusible links if any.
Jun 1, 2016 at 10:57 AM
