Engine emitting black smoke
18,500 MILES • 1.3L • 4 CYL • 2WD • AUTOMATIC
ANESU
Bought a Honda Fit but it is emitting black exhaust smoke.
Jul 25, 2019 at 3:53 AM
SCGRANTURISMO
  • 4,897 POSTS
Black smote emanating from your vehicle's exhaust is a sign that your vehicle is burning too much fuel. Here is a link for you to go to below:
https://www.2carpros.com/articles/engine-black-smoke
Please go through this guide and get back to us with what you are able to find out.
Thanks,
Alex
2Carpros
Jul 25, 2019 at 5:44 AM
ANESU
Thanks Alex the information was helpful
Jul 26, 2019 at 9:58 PM
  • 55,658 POSTS
It sounds like you have a struck injector. how is the engine running? Can you please shoot a quick video with your phone so we can see what's going on? that would be great. You can upload it here with your response.
Jul 29, 2019 at 4:11 AM
ANESU
I changed the injectors, cam sensor, EGR valve, TP sensor and the computer. but the problem of emitting black smoke is not changing.
Jul 29, 2019 at 7:06 AM
ANESU
The same car the CVT gearbox not changing gears its like it is stuck in one gear.I removed the gearbox and put it on another car it is driving perfectly well.took a gearbox that was driving well and changing gears I put it on this car and it is not changing gears what could be the problem
Jul 29, 2019 at 7:17 AM
  • 55,658 POSTS
Hmm, it could be the catalytic converter is partially clogged causing both issues but to confirm the issue here is a guide.
https://www.2carpros.com/articles/how-to-test-a-catalytic-converter
and
Jul 30, 2019 at 3:45 AM
