Engine revved to 6,000 RPMS, all dash lights turned on and the car shut off?
128,000 MILES • 2.4L • 2WD • AUTOMATIC
RKILBURG06
When driving, I attempted to pass a vehicle. Car revved up to 6,000 RPMs and then all lights came on dash and car shut off. Coasted to a stop, attempted to cycle ignition to restart, and had click and tried to turn it over but quickly lost power as if the battery was draining. Replaced alternator and battery tested good. Even while jumping, when starting it draws down the battery power and tries to crank but no turnover. Interior lights flicker when trying to crank.
Dec 19, 2022 at 1:41 AM
  • 55,561 POSTS
I would recheck the battery because this sounds like the battery has an internal short. Also, we should run the codes to see if any come up. Also, check the battery cable connections. If you can upload a short video of what the car is doing, I can tell for sure what's going on.
and
Dec 19, 2022 at 4:31 AM
RKILBURG06
I will see about a video when I can get to it next. But there were no codes which I found odd since I had dash lights come on at the time.
Dec 19, 2022 at 4:42 AM
  • 55,561 POSTS
It does sound like a connection problem, I would recheck the battery because an internal problem can come and go with batteries.
Dec 20, 2022 at 2:44 AM
RKILBURG06
The second test came back as a bad battery, so I replaced it. It resolved the lights flickering and draining issue. However, I still cannot start. You can hear where it stops and grabs. My thought is 1) if the camshaft position sensor isn’t letting a full rotation? 2) the engine is locked up 3) the starter is coincidentally bad. Thoughts?
Dec 20, 2022 at 11:08 PM
  • 55,561 POSTS
Thanks for the video. I would remove the spark plug and then crank the engine over to see if coolant had filled one of the cylinders. When you crank the engine over stand back in case coolant shoots from the engine spark plug hole. If okay, I would replace the starter.
https://www.2carpros.com/articles/how-to-change-spark-plugs
Here is how to change out the starter in case you need it. Check out the images (below). Please let us know what happens.
Dec 22, 2022 at 6:23 AM
