engine effortly start and emmision carbon smoke
45,000 MILES • 1.6L • 4 CYL • FWD • MANUAL
ZAVERIZAVERI
Sir, I have hundai accent viva 1.6 petrol car, it run fine but from last two days I show problem to start car and see some black smoke emmision behind , my question is why it happen?
What I suggest mechanic to repair?
Is my clutch plate is to be replace?
Or I have to clean my engine (decarbonised) ?
Kindly advice me ....regards
Dec 19, 2013 at 12:13 PM
  • 110,251 POSTS
Since there is black smoke, chances are the air / fuel mixture is off (too much fuel to the engine). Is the check engine light on?
Dec 19, 2013 at 10:01 PM
ZAVERIZAVERI
Thank s for reply but my michenic says there is problem in fuel injector and power is not supply properly that is why engine just start and stop and blacksmoke emmision..
Dec 19, 2013 at 10:19 PM
  • 110,251 POSTS
That is possible. I just said it is getting too much fuel so the injectors could be sticking. Or, you could have a bad fuel pressure regulator.
Dec 19, 2013 at 10:40 PM
ZAVERIZAVERI
Yes may be anyway I thank full to you to get some right advise and solve the problem.
Dec 20, 2013 at 2:22 AM
  • 110,251 POSTS
Let me know what you find.
Dec 20, 2013 at 2:49 AM
ZAVERIZAVERI
Yes sir, I replace two injector and problem is solve ...
Dec 21, 2013 at 4:54 AM
  • 110,251 POSTS
Great! Glad you got it fixed. Have a great Holiday and let us know if you have other questions.
Dec 21, 2013 at 9:03 AM
