Sir, I have hundai accent viva 1.6 petrol car, it run fine but from last two days I show problem to start car and see some black smoke emmision behind, my question is why it happen?
What I suggest mechanic to repair?
Is my clutch plate is to be replace?
Or I have to clean my engine (decarbonised)?
Kindly advice me. Regards
SPONSORED LINKS
Thursday, December 19th, 2013 AT 8:13 PM
MECHANIC
Since there is black smoke, chances are the air / fuel mixture is off (too much fuel to the engine). Is the check engine light on?
Friday, December 20th, 2013 AT 6:01 AM
ZAVERIZAVERI
MEMBER
Thank s for reply but my michenic says there is problem in fuel injector and power is not supply properly that is why engine just start and stop and blacksmoke emmision.
SPONSORED LINKS
Friday, December 20th, 2013 AT 6:19 AM
MECHANIC
That is possible. I just said it is getting too much fuel so the injectors could be sticking. Or, you could have a bad fuel pressure regulator.
Friday, December 20th, 2013 AT 6:40 AM
ZAVERIZAVERI
MEMBER
Yes may be anyway I thank full to you to get some right advise and solve the problem.
Friday, December 20th, 2013 AT 10:22 AM
MECHANIC
Let me know what you find.
SPONSORED LINKS
Friday, December 20th, 2013 AT 10:49 AM
ZAVERIZAVERI
MEMBER
Yes sir, I replace two injector and problem is solve.
Saturday, December 21st, 2013 AT 12:54 PM
MECHANIC
Great! Glad you got it fixed. Have a great Holiday and let us know if you have other questions.
