Engine shutting off while driving
JDSAUERSR
  • 2006 PONTIAC G6
  • 3.5L
  • 6 CYL
  • 150,000 MILES
I had it scanned at AutoZone and it says catalytic converter. I think the crank shaft sensor is causing the issue. Would replacing fix this problem?
Friday, February 15th, 2019 AT 2:15 PM
  • 110,055 POSTS
A plugged catalytic convert can cause the engine to stall. It will also cause a loss of power among other issues. Can you provide the code they found? Also, why do you suspect the cam sensor with the code?
Take a look through this link to see if anything mentioned mirrors what you have experienced.
https://www.2carpros.com/articles/bad-catalytic-converter-symptoms
Here is a link that shows how to test a catalytic converter:
https://www.2carpros.com/articles/how-to-test-a-catalytic-converter
Now, when you first said it stalls while driving, my first thought was fuel related. However, it could also be related to a crankshaft position sensor. Regardless, since you have the catalytic converter code, let me know what it is so I can help better diagnose the problem.
Friday, February 15th, 2019 AT 2:37 PM
