engine draining battery crazy, idle crazy, then stalls on the streets
200,000 MILES • 1.6L • 4 CYL • 2WD • MANUAL
JASONFATHOMS
  • 6 POSTS
my engine is draining my battery like a vampire=! when the battery gets low enough, WHICH IS IN ONLY A FEW MILES the car goes into death mode WITH THE IDLE FLIPPING OUT WITH SHAKING AND THEN IT DIES IN THE MIDDLE OF A BUSY STREET. I THINK I KNOW WHERE THIS MAJOR PROBLEM ORIGINATED FROM BECAUSE I WAS THOUGHT TO BELIEVE I FOUND IT! I HAD TO LENGTHEN ONE OF THE 02 SENSORS BECAUSE I PURCHASED A NEW EXHAUST. SO I ELECTRICAL TAPED UP ALL THE CONNECTIONS NICELY THINKING THERE WOULD BE NO PROBLEMS. AFTER THAT IS WHEN THINGS STARTED TO GO BAD!
JUST TODAY I WAS GOING THROUGH MY ENGINE AND REALIZED THAT THE WIRES FROM THE DOWNSTREAM O2 SENSOR WERE BURNED UP AND MASHED TOGETHER TOUCHING! SO I WAS RELIEVED THAT I FOUND THE PROBLEM!!!!!!! YAY!!!!!
BUT NOT EXACTLY THE PROBLEM BECAUSE IT IS BACK TO THE DRAWING BOARD AGAIN! WHAT CAN I DO? CHECK FUSES? POSSIBLY RESET THE ENTIRE SYSTEM? HEEEEEEEEEELP! ITS DRIVING ME CRAZY AND I WORK 35 MILES AWAY!
THANKS!
Nov 7, 2015 at 7:53 AM
CJ MEDEVAC
  • 11,000 POSTS
YOU HAD THE ALTERNATOR TESTED AT A POPULAR AUTO PARTS STORE?
AT MINIMUM
WHAT ARE THE RESULTS USING THIS?
www.youtube.com/watch?v=LGB6ZEjGm7Q
THE MEDIC
Nov 7, 2015 at 10:39 AM
JASONFATHOMS
  • 6 POSTS
I just got an alternator from the junk yard because autozone said it was bad. but it didnt fix the problem. it is possible that the used alternator is no good also like autozone said again. is there anyway i can check the alternator off the vehicle?
Nov 8, 2015 at 9:23 AM
CJ MEDEVAC
  • 11,000 POSTS
YES!
YOU CAN GET A BENCH TESTING MACHINE LIKE AUTOZONE HAS
OR
YOU CAN TAKE IT TO THEM AND LET THEM TEST IT ON THEIRS
IF YOU DOUBT THE SKILLS OF THE EMPLOYEE YOU HAD LAST TIME
GO TO A DIFFERENT AUTO PARTS STORE
DID YOU TEST YOURS AS PER THE LINK I PROVIDED BEFORE?
IF THE ALTERNATOR TESTS GOOD, BUT STILL NOT CHARGING THE BATTERY, YOU MIGHT CHECK CONNECTIONS, FUSES, AND FUSIBLE LINKS, BROKEN WIRES.
A VOLTMETER IS A GREAT TOOL TO HAVE FOR NOW AND THE FUTURE, THEY ARE A MUST TO DIAGNOSE WITH, IT'LL SAVE YOU MEGA DIAGNOSTIC TIME.
YOU CAN GET A DECENT, CHEAP, DIGITAL VOLTMETER AT "HARBOR FREIGHT" FOR ABOUT $5. AT AN AUTO PARTS STORE THEY MAY BE AS HIGH AS $20.
THERE ARE MANY "YOU TUBE" VIDEOS THAT CAN SHOW YOU ALL KINDS OF WAYS TO USE ONE.
SHOULD YOU NEED SOMETHING ELSE $$$
PLEASE CHECK OUT THIS LINK BELOW. CURRENT GOOD PROMO CODES ARE "TRT30" (BEST FOR ME NOW) "A124" (STILL WORKS, NOT AS GOOD AS IT DID) AND LOOK FOR OTHERS THAT MAY DO BETTER ONLINE
https://www.2carpros.com/questions/2001-dodge-neon-milage-just-want-put-fliuds-their-locations
KEEP US POSTED
THE MEDIC
Nov 8, 2015 at 11:01 AM
JASONFATHOMS
  • 6 POSTS
I bought a rebuilt alternator off ebay. Oreillys passed it with flying colors. THE PROBLEM PERSISTS. I KNEW DEEP DOWN INSIDE FROM THE GET GO THAT THEM WIRES CROSSING FOR I DONT KNOW HOW LONG FRIED SOMETHING IN THE COMPUTER I THINK?
Nov 14, 2015 at 8:45 AM
JASONFATHOMS
  • 6 POSTS
GOT NEW ALTERNATOR. PASSED ALL TESTS, PROBLEM STILL PERSISTS!
I AM AT A VERY DIFFICULT TIME OF MY LIFE RIGHT NOW. AND THIS IS ADDING ICING TO THE CAKE...
Nov 14, 2015 at 8:48 AM
CJ MEDEVAC
  • 11,000 POSTS
LOOK AT THE INFO IN THIS LINK
https://www.2carpros.com/questions/1996-buick-park-avenue-runs-battery-down-in-2-days
MAYBE IT WILL HELP IN SOME WAY
THE MEDIC
Nov 14, 2015 at 11:25 AM
JASONFATHOMS
  • 6 POSTS
i just found out what it was yesterday.
i google searched touching o2 sensor wires or something of that nature, and FUSE 15 popped up. I CANNOT BELIEVE I PRACTICALLY WENT THROUGH HELL WITH ALTERNATORS WHEN THEY WEREN'T THE PROBLEM. I APPRECIATE YOUR HELP AND CONCERN..
Nov 16, 2015 at 8:27 PM
JASONFATHOMS
  • 6 POSTS
I SWEAR I LOOKED AT THE FUSES BEFORE. I MUST HAVE SKIPPED THAT ONE OR DID NOT NOTICE IT CUZ THERE IS SOOOOO MANY.
Nov 16, 2015 at 8:31 PM
CJ MEDEVAC
  • 11,000 POSTS
VERY WELCOME!
GLAD YOU GOT IT!
FEWER PROBLEMS IF YOU HAD A JEEP!
COME BACK TO SEE US
THE MEDIC
Nov 18, 2015 at 12:41 PM
