Engine do not start- got spark and fuel pressure
150,000 MILES • 2.5L • V6 • 2WD • AUTOMATIC
B182
Hi, I've got a problem. My car's engine just stopped during drive and there was no spark. So I decided to change distributor and computer. After that car started and was running on idle for 3-4 minutes. Then the engine started to slow down and finally stopped . So I checked the spark, fuel pressure, compression etc. It looks ok but it still doesn't start. Previously the computer was faulty. Replacing of it solved the problem. Now my mechanic do not know what to do. Is it computer again?
Nov 4, 2015 at 8:13 PM
WRENCHTECH
  • 20,760 POSTS
Computers don't generally fail on their own. They are killed by other issues in the car so when you replace a computer, you still need to find what killed it.
As for current troubleshooting, you need to go back to checking spark, fuel and compression because one or more of those functions has a problem.
Nov 4, 2015 at 8:42 PM
