Engine does not have power
200,000 MILES • 1.3L • 3 CYL • 2WD • MANUAL
JEREMIAH MATLOU
  • 6 POSTS
The vehicle uses too much oil and even having blue smoke. It was taken in for repair and mechanic worked only on the top but the problem is still there.
Mechanic said he will work on the block.
Sep 11, 2018 at 8:30 AM
Good evening.
It sounds like the piston rings are the issue.
He can confirm by doing a compression test both wet and dry. The wet test is done by adding a little oil into the cylinder and rechecking the compression. If it rises, then the rings are bad and need to be replaced.
Sep 11, 2018 at 8:52 AM
JEREMIAH MATLOU
  • 6 POSTS
Should he put standard piston rings or it need to be taken to engineering to bore the block?
However, he said he could not notice any sign of ridge on the block. This is just a question of clarity with you Roy.
Sep 11, 2018 at 8:58 AM
He will have to check the cylinder bore and taper for out of round and taper. If it has taper and out of round, then yes, it needs to be bored out with new pistons.
Sep 11, 2018 at 9:00 AM
JEREMIAH MATLOU
  • 6 POSTS
This piston rings, should we use market or non-market, meaning the one from the dealership or we can buy from any auto spares?
Sep 11, 2018 at 9:01 AM
You can get them at a parts store. As long as they are the correct size.
Sep 11, 2018 at 9:08 AM
JEREMIAH MATLOU
  • 6 POSTS
Thanks Roy.
Sep 11, 2018 at 9:15 AM
You are welcome. We are always glad to help.
Sep 11, 2018 at 9:16 AM
RENEE L
  • 1,260 POSTS
Hello JEREMIAH MATLOU,
Thank you for using 2CarPros.com. Please post your question regarding the Ford Ranger here: https://www.2carpros.com/questions/new
The site cannot properly index the question, as you are asking about a different issue and vehicle.
Thank you and have a great rest of your day!
Renee
Admin
Sep 12, 2018 at 4:28 AM
