Engine disabled message and codes p0107, p2101, and p0651
121,000 MILES • 2.4L • 4 CYL • 2WD • MANUAL
ALLENSEBI
Just put in new clutch then put car back together and now I am getting an engine disabled message on dash.
Getting codes p0107, p2101, and p0651.
It is not a key security issue.
Mar 29, 2022 at 5:30 AM
  • 110,248 POSTS
Looking at the codes, the first thing I would suggest checking is the gray wire between the PCM and the throttle pedal position sensor. So, go to the TPP sensor and disconnect it.
Using a voltmeter or multimeter, check for a 5v reference.
The PCM is in the left rear of the engine compartment, so the wire may have been damaged, pinched, or disconnected.
Let me know what you find.
See pic below.
Mar 30, 2022 at 1:52 PM
