I have an RV on a 1984 g30 chassis.
It will run perfectly normal until the engine heats up, then it will stall and shut off. I have to wait for it to cool down before I can start it again, this was minor 700 miles ago, it has since gotten to the point where I can only go 10 miles down the road. I’ve replaced the power steering pump, alternator, rebuilt the carburetor, bypassed the mechanical pump with an electric (I put the plate in and took the pump off), I’ve heat shielded the fuel lines because I guessed vapor-lock.
The only thing that is making me uneasy is that when I start up and it does the stalling thing, there’s a growl that (to me) sounds like something slowing the engine down, it’ll putter then shut off.
I’m 500 miles from home and I don’t know what to do at this point.
The video is the growl.
Jun 17, 2019 at 7:46 AM
