Engine Dies When stopped and trans. is in 4 wheel drive
148,000 MILES • 6 CYL • 4WD • AUTOMATIC
BPANK3
My engine dies when I am at a stand still and my trans is in 4 wheel drive. When in 2 wheel drive it seems to be fine. Any ideas on what could cause this?
Feb 5, 2014 at 5:43 AM
HMAC300
  • 48,601 POSTS
I could be something in tcae binding but try cleaning throttle palte on both sides with choke cleaner and iac hole see if that helps also check fluid level in tcase. It may be something simple. if not then have a local guy look at it.
Feb 5, 2014 at 7:50 AM
CHAVO2177
  • 33 POSTS
when mine did that I found that a wire harness close to the trans. had broke the little plastic piece that hold it in place and allowed it to move and twist to where 2 wires were rubbed down to bare wire and were touching. Not saying that is the problem with yours but might be a place to start,
Feb 25, 2014 at 11:42 PM
