Engine Dies after being driven and parked for short period then started and driven
140,000 MILES • 2.2L • 4 CYL • FWD • AUTOMATIC
JIM10409
My daughter has a 1997 Cavalier, 2.2L, Automatic, has a little over 140,000 miles. While driving down the road it will randomly die after being driven for a period of time parked and re-started and driven again (won't make it very far after being re-started). Doesn't seem to be any consistent thing happening. Sometimes does it while stopping and other times while taking off. Usually has to sit for a few minutes before it will restart. Runs fine other than the random dying. The check engine light is not on and the code scanner shows no stored codes. Has a new fuel filter, new plugs and new wires. It doesn't do it regularly and I haven't had it happen yet while I'm driving. Has not happened for about three weeks this time. The only thing that seems different is out side temps. I believe it seems to occur more in warmer temps 85 t0 90 degrees.
Jun 16, 2014 at 7:11 AM
SATURNTECH9
  • 30,868 POSTS
When it doesnt start check for spark you have a bad crankshaft position sensor.
Jun 18, 2014 at 3:34 PM
