Engine shuts off after three seconds after rebuild
170,000 MILES • 2.4L • 4 CYL • 4WD • MANUAL
TANNER NELSON
So, I just finished putting my engine back together.
Here is what I have replaced:
Pistons.
Piston rings.
Rod bearings.
Main bearings.
Thrust bearings.
Head gasket.
Valves.
Timing belt.
Tension-er pulley.
VVT solenoid.
Starter motor.
Fuel filter.
Last night after I finally got it back together and tried to start it up. It runs for maybe three seconds with loud random squeaking and then just shuts off. It almost sounds like the piston rings get stuck or something. I know the timing was all lined up before I started it up. Any suggestions of possible issues? Thanks
May 22, 2018 at 3:48 AM
  • 55,748 POSTS
Can you shoot a video with your phone of the noise and upload it here so I can hear what is going on? That way I can tell for sure.
Cheers, Ken
May 24, 2018 at 5:50 AM
