This car LE model V6 sat several years. Fuel tank dried out so I had to put a new fuel pump and tank in. Did that and started up the car with fresh gas. Drove it to a new location a mile a way, total time ran engine was 15 minutes. Now, the car starts, but shuts itself off after exactly 15.5 seconds (give or take .25 seconds.) It only ran longer one other time, I willingly turned it off with the key. It seems scientific since it is always the same time it turns itself off. Is there some kind of "safety" mechanism that is shutting the car off and why? The only thing that I know of is wrong with the car is that I have to use the bypass button to shift gears. What causes the shift button to no longer function? More importantly is getting the engine to stop shutting itself off.
May 28, 2019 at 5:09 PM
