Engine shut off and will not turn over
140,000 MILES • 3.4L • 6 CYL • 2WD • AUTOMATIC
SEAN DOLAN
Lost power while driving. When trying to turn over engine there is just a winding noise, but no crank from the engine. Was having idle issues when stopped before this.
Dec 30, 2016 at 4:21 AM
HMAC300
  • 48,601 POSTS
it may be the starter drive gone out on starter. if you can hear starter winding up and running then it is a starter.
Dec 30, 2016 at 4:52 AM
SEAN DOLAN
Would that cause idiling issues too?
Dec 30, 2016 at 4:55 AM
HMAC300
  • 48,601 POSTS
try cleaning throttle plate on both sides and IAC hole with choke cleaner for idle.
Dec 30, 2016 at 5:41 AM
