Engine shut off and will not start
174,000 MILES • 3.3L • V6 • 4WD • AUTOMATIC
JASON SMITH3
It was running perfect and the engine shut off and it will not start. it is getting good spark and good fuel pressure but spark plugs are dry.
Jul 20, 2017 at 3:04 PM
JOHNNY71
fuel pump relay. starting fluid tells a lot if it starts you do not have gas injectors. i think you know you are not getting gas.
Jul 20, 2017 at 4:17 PM
  • 55,732 POSTS
Lets test the injector pulse to see if the PCM is sending a signal.
Here is a guide to show you how to test it:
https://www.2carpros.com/articles/how-to-test-a-fuel-injector
Please run this test and get back to us we are interested to see what it is.
Cheers, Ken
Jul 21, 2017 at 6:56 AM
