The engine shut off and will not restart?
190,000 MILES • 3.3L • V6 • 2WD • AUTOMATIC
DURK DABROWSKI
  • 30 POSTS
It felt like it was running out of fuel. i can still hear the fuel pump work when i try to restart it.
Jul 13, 2024 at 6:29 AM
  • 55,748 POSTS
How does it sound when it is cranking over? Can you upload a short video so I can hear it that way I can make sure the engine is not hurt. Also, let's check for spark which video will help you do.
https://youtu.be/baq_aEWNQ0Y?si=XFPy1s3jM04lRKV9
Please go over this guide as well:
If there is no spark, I would swap out the crankshaft angle sensor here is the location of the sensor in case, you need it. Check out the images (below). Please let us know what happens.
Jul 14, 2024 at 3:13 AM
