engine shut off and everything went black
110,000 MILES • 4.3L • V6 • 2WD • AUTOMATIC
CLASSICMAN
I started my engine drove it for like two minutes before I can get out of the driveway, and the engine shut off. I tried to start it but all does it crank over with no start. I have a brand new battery in it, the headlights will not turn on, the radio will not turn on, dome light will not work and I cannot hear the fuel pump turn on. Power windows windshield wipers turn, but panel does not come on. This is the first time that my van has ever given me any problems. And you think this could possibly be a passkey problem? because I have read that these vans have a passkey security installed in them.
Jan 21, 2017 at 12:46 AM
CJ MEDEVAC
  • 11,000 POSTS
Even a new battery can be bad right off the shelf.
Can go bad hours/days/ weeks later.
Usually not the case.
Have you tested the voltage between the battery posts/ terminals with a digital voltmeter ($5.00 at Harbor Freight) Setting 20 volt DC, you should have at least 12.5 Volts on the display.
Something could have drained your battery (called a parasitic drain, some are normal, others like a light not turning off and many other possibilities also).
Let's ignore that for now.
If you do have good voltage, this might be the most common issues, usually sorta gets ignored too.
See all of my EZ possibilities in this link! Pics at the end.
https://www.2carpros.com/questions/1996-chevrolet-tahoe-wont-start-sounds-dead-battery-jumpbox-get-same-reults
Return with good news, or your findings thus far.
The Medic
Jan 21, 2017 at 4:02 AM
CLASSICMAN
Battery is good and so are the connections. engine cranks over just will not start. as i was pulling out of my driveway the engine just cut out. no headlights, no radio and cannot hear the fuel pump turn on, when before i could. power windows work and wipers work.
Jan 21, 2017 at 4:20 AM
CJ MEDEVAC
  • 11,000 POSTS
This is from the top of the page under "Repair Guides"
https://www.2carpros.com/articles/how-to-reset-a-security-system
Maybe it will aid you.
The Medic
Jan 21, 2017 at 10:47 AM
