Shut off while driving, engine cranks but does not start?
96,000 MILES • 4.3L • V6 • 2WD • AUTOMATIC
GIGGLESGARD
It will crank but not turn over. Checked the spark plugs and they are good. Checked fuel line and it also is working.
Nov 19, 2022 at 1:16 PM
  • 110,248 POSTS
When you have a crank with no start condition, it usually is the result of either a fuel-related or ignition-related issue.
Take a look at this link.
https://www.2carpros.com/articles/car-not-running-advanced
Here is what I want you to try. See if the engine starts using starting fluid. If it does and then stalls, we will know it's a fuel-related issue. If there is no change, then I need you to check for spark to the plugs.
Here is a link that explains how to check for spark:
https://www.2carpros.com/articles/how-to-check-for-ignition-spark
Start with this and let me know the results.
Nov 19, 2022 at 2:33 PM
