engine diagram?
250,000 MILES • 2.8L • V6 • 2WD • AUTOMATIC
LEYNA07
  • 41 POSTS
i have an issue just recently opened my hood and I've noticed to right side of engine drivers' side to far right I've noticed a frozen hose that I've never seen before like that. i have no clue to what or where it goes to figured a diagram with labeled parts would be of help to see if i can match the location.
I've also just drove and suddenly brake pedal went all way down haven't looked into to common problems for that would be yet i have trouble finding a manual online for free for my year make and model listed above sedan.
Dec 26, 2022 at 7:55 AM
  • 110,248 POSTS
As far as the brake pedal is concerned, chances are either there is a ruptured brake hose, or the brake master cylinder has failed. Take a look at this link. I feel it will be helpful and of interest to you.
https://www.2carpros.com/articles/brake-pedal-goes-to-the-floor
Do me a favor. Check the brake fluid level. If it is low or empty, we have a leak. If there is still fluid, chances are the master cylinder has failed.
Next, can you upload a pic of the hose? Also, how large is it? You indicated it froze, so there must be a frozen liquid in it. Could it be the windshield washer fluid supply?
Let me know. A pic would be helpful for the hose. Let me know your thoughts and findings about the master cylinder fluid level and the link I attached.
joe
Dec 26, 2022 at 2:04 PM
