Engine derated?
48,000 MILES • 1.5L • 4 CYL • 4WD • AUTOMATIC
DAVENPORT
Great little car. Zero problems until now. Loaned car to granddaughter. Came back derated. Codes said wheel sensors - replaced. Then Pedal sensor - replaced twice. Then throttle body - replaced. Then still would not communicate with the ECM - replaced. Still doesn’t communicate. Please help!
Jul 8, 2025 at 9:04 AM
  • 55,694 POSTS
The ECM will not communicate if you have a fuse out. I would check the ECM and ECM? TCM fuses under the hood and the fuse #6 in the battery fuse panel near the battery (250amp). This guide can show you how:
Also, check the "DLC left" fuse in the fuse panel on the left side of the dash. You might want to go over this video as well:
https://www.youtube.com/watch?v=6Tlg3JmgNSQ
Please go over these guides and get back to us.
Jul 9, 2025 at 11:38 AM
DAVENPORT
Thank you, Ken L. We will check the fuses as you have directed and report back. Appreciate your help immensely!
Jul 9, 2025 at 5:45 PM
  • 55,694 POSTS
Sounds good :) have a good day!
Jul 10, 2025 at 2:46 AM
DAVENPORT
The problem was the electrical harness between the pedal sensor and the ECM. To find it required 2 pedal sensors, throttle body, ECM, and then the harness. I appreciate your reply, as it put the person diagnosing the problem onto the sleuthing it took to discover what was wrong. This was a very difficult repair to find. One wire in miles of electronics. The repair recommended sequence did not point to the harness - this was a rare problem.
Aug 14, 2025 at 2:14 PM
  • 55,694 POSTS
Yep, they happen, nice work finding the problem and getting back to us. Please use 2CarPros anytime we are here to help.
Aug 15, 2025 at 5:13 AM
