Engine cuts out while driving
177,000 MILES • 2WD • AUTOMATIC
IVAN CLARK
Vehicle listed above has a Tdci Auto, Diesel. had mot done 3 months ago was running fine. Has sat since then now it cuts out when driving every time.
Oct 8, 2020 at 7:33 PM
We need to start with checking for codes. If there is a code that can point us in a better direction then we need to chase that. If not, a diesel engine needs compression and fuel to keep running. So we need to suspect that we are losing fuel pressure to cause this to cut off. That means we need to check fuel pressure when this cuts off to see if it is dropping.
Also, did you change out the diesel fuel or is this the same fuel that was sitting in the tank from a few months ago? If so, it could have moisture in it or be stale at this point. I would suggest draining the tank, putting new fuel in, and a diesel fuel conditioner then see if it continues to stall.
Let me know and we can go from there. Thanks
Oct 9, 2020 at 10:56 AM
