Engine Cuts off
2002 NISSAN X-TRAIL
56,400 MILES • 2.5L • 4 CYL • 4WD • AUTOMATIC
CKOME
Hi there,
Mu Xtrail engine juts can't off when i offed the engine and now wont start..
if you can advice accorginly.
thanks
carla
Jul 24, 2019 at 10:24 AM
  • 110,240 POSTS
Welcome to 2carpros.com
If I understand, you shut the engine off and it hasn't started since. Is that correct? If so, is the starter engaging and turning the engine? Have you checked to see if there is spark and fuel to the engine?
Take a look through this link to see if it helps. It discusses the most common causes for a crank / no start condition.
Also, you may want to check for spark and fuel to the engine. Here are links for that.
Jul 25, 2019 at 12:03 PM
