when i remove the crankshaft sensor fron the engine and test it with an ohm meter what resitance should i get if sensor is NOT bad?
Apr 26, 2013 at 2:29 AM
WRENCHTECH
✓Experienced Mechanic
A resistance test will rarely tell you anything as to the functionality of a Crank sensor. It needs to be tested using a lab scope and comparing wave patterns.
Apr 26, 2013 at 2:59 AM
JDL
They don't call it a crank sensor. I found an engine speed sensor.
Condition: min to max resistance.
Terminals: 1,2
specification: resistance
Low value: 1000000000.0
High value: the same
Unit of measure: ohms
Terminals: 1,3
Specification:
Same as above.
Terminals: 2,3
Specification: resistance
Low value: 730.0
High value: 1000.0
Unit of measurement: ohms
