Starts for three seconds then shuts off
30,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
FLEX41
engine cranks. start for three seconds then shuts off.
Jan 26, 2018 at 8:46 PM
KHLOW2008
  • 41,812 POSTS
Most probably a fault with one of the sensors. You need a diagnostic scan to check for trouble codes which could tell you which sensor is causing the problem.
Jan 26, 2018 at 10:11 PM
WRENCHTECH
  • 20,760 POSTS
I would first look around for any type of security indicator. The symptom could be an immobilizer not recognizing the key for some reason. If you eliminate that possibility, then you should do a fuel pressure test as it sounds like it is starving for fuel.
Jan 27, 2018 at 12:50 AM
