Engine shut off while driving it cranks no start
225,190 MILES • 3.0L • V6 • 2WD • AUTOMATIC
JEFF FALLEN
it has spark and fuel pressure and good compression. i was getting off freeway car was running great got off on off ramp and it was like i cut it off with key.i checked injectors they are hot when you turn key to run. i am not getting a signal on the pulse when cranking it over.
Jul 30, 2019 at 3:43 PM
SCGRANTURISMO
  • 4,897 POSTS
If you have compression, spark, and fuel there should be no reason why your vehicle wouldn't start. What do you mean by you are not getting on the pulse?
Thanks,
Alex
2CarPros
Jul 31, 2019 at 12:33 AM
